port tuning question
i would rather be able to do it with brains rather than be lazy and use some online calculator like so many lazy fvcks do.
out side dimensions are 13.5 high, 17.5 deep, 34 inches wide, its build from 3/4 MDFThe port in side dimentions are 3" wide 12" tall 14" deep
EDIT: driver displacement is .068
K, now calculate your net volume from that. You need to get the xmax value for the drivers. Put all that info into here. http://www.subwoofertools.com/forum/ported-box.asp
Adjust the tuning frequency until the correct total port area is found. Whatever that frequency is, is the frequency of the box with the drivers you chose.
all u do is take the total cubic feet of the box and the size of the port and plug that into winisd and it will give u a port length, and lets say ur port length is 30" long but ur box is only 20" deep... the port has to go the difference of that each way not the length cut in half and L off each way ... mmm hope that makes since
i want to know how to figure tuning for a box like pictured at the beginning of this thread.does anyone see how the port is ran in that box?
brokeitagain
auto body tech:)
brokeitagain
MO
jmrunz
vegang
vegang
