port tuning question
brokeitagain
auto body tech:)
334
MO
ok i borrowed this pic from fischer customs.
how do u figure the tuning on a box that uses a shared port in between the drivers. I am hoping for a detailed explanation. thanks
I hope fischer customs does not mind me using their pic.
That guy builds some nice stuff
i would much rather get a technical explanation of how properly figure it. i dont want to trust some online calculator that may be way off.
i want to know how to figure the volume and tuning of an enclosure like the one that is pictured above. i know how to do it if the subs are in the same chamber but is it different when the enclosure is built as the one above?
As far as I know, most people use the online calculator or Winisd. I may be wrong though. I have no clue how you would calculate the tuning out by hand. I would kinda like to know that myself. Even though the two chambers in your picture are separated, they share the same port. Again, I may be wrong, but i think you can calculate it just as if the two chambers were connected. Use the combined volume of the two.
thats what i was thinking originally. Now i think that it is supposed to be two separate chambers then figure the port in somehow
thats where i am lost at.
i am trying to figure out the tuning on the box i might buy to use with the new subs i bought. The audio shop says it is built for these but( i know that they did build it)i want to know what it is tuned to before i spend 60 bucks on it. If its not what i want i will build my own to suit my desires
Just plug in the internal volume of your box(minus port/subs), port area, and port length into a calc and it'll tell you the tuning frequency. There's nothing special or tricky to having two subs and one port.
If you were to calculate them separately maybe you would divide the port area in half? 1/2 for each driver? hmmm.... im lost. You could try calculating both ways and see how much they differ.
thats what i meant i know it is kinda difficult to understand what i mean until u think of how the port is arranged in the box
that isnt what i need to know, I WANT TO MEASURE THE BOX I AM LOOKING AT THAT I AM CONSIDERING BUYING, SO I KNOW THE TUNING FREQUENCY OF THIS BOX WILL BE WHAT I OR NOT
out side dimensions are 13.5 high, 17.5 deep, 34 inches wide, its build from 3/4 MDF
The port in side dimentions are 3" wide 12" tall 14" deep
EDIT: driver displacement is .068
brokeitagain
auto body tech:)
brokeitagain
MO
jmrunz
vegang
vegang
