port tuning question
this enclosure does not have the divider in the port
are you seriously still confused??? Both subs share the port, like in this box:
As I said before, there's no secret to this. You can use one port for 1000 subs...the number of subs does not matter.
what i wanted to know is how to figure a port that does L off into the chambers on both sides,whit no divider
The part that branches off into each side will be one half the width of the original port. An easy way to think of it is "however long you would need to go past the back of the box, that's how far, from the center of the original port, that you need to branch off into each side."
******* **** is everybody blind cant u look at the pic i posted and see how the port is in there?
now stfu.
you just want the math formula to figure it out yourself right? i was looking for the same thing a while back and couldn't find nothing!!! i kept finding all those different calculators (re audio calc, the subwoofer tools one, winisd, etc) but then i read a bunch of things in these forums and other places that those calculators aren't that accurate. so good look man i looked for a while!
brokeitagain. dont get discourraged people just tell you what they know. with that here is what i know.
when you build a box for 2 subs shared space the volume needs to be big enough for both subs. say each sub requires 2 cubes then you need a 4 cub net box. keep in mind that that is after port and sub displacement. you can easuly end up with a 5.5 cube box to get 4 cubes net.
a rull of thumb we use is 16 inches squared per cubic foot of box volume. when you run a divider in the center of the port dividing the chambers up the playable area comes back into each chamber a bit.
port tuning is dependand on surface area and depth of port. the smaller the surface area the higher port noise you have. if you go to ddaudio.com and use their calculator it works real good but you want to figure it out yourself i have a couple of formulas and web sites you can visit to get these for yourself and i hope they help you as they have helped me a ton.
here they are.
http://www.realmofexcursion.com/forum/showpost.php?p=447126&postcount=1.
http://www.caraudio911.com/tutorials/PortedBox/images/001.gif
http://www.usenclosure.com/Enclosure%20Formula's/enclosure_formula.htm
and here are some difinations of abreviations
.Lv = port length (what your solving for)
Av = your port area (height x width of the port face)
Vb = the internal volume of your box
Fb = the tuning frequency you want
again i hope these pages and info helps you in what you want.
james
brokeitagain
auto body tech:)
brokeitagain
MO
jmrunz
vegang
vegang
