port questions
LUV2BHATED
BRONX NY
Might be a dumb question but better to ask and know then to not ask and build. now im building a box for 2 12in l7's now with the port, would it be a big difference if its a square port in the middle or 2 pvc pipes to be the port? wut would u suggest??????
can a port be on the opposite side of the box? speakers on one side the port on the other??
it CAN, but that ought to introduce nasty cancellation.
Best option=subs and port on the same plane.
Next best=subs and port 90 degrees of axis.
Least=180 out of phase with your subs.
it CAN, but that ought to introduce nasty cancellation.Best option=subs and port on the same plane.
so what if the sub is firing up and a 6" aeroport firing to the rear would this work good
Well I ordered an oscope. Should be here today. And this beautiful beast showed up today. I’m gonna have to redo my battery and ground terminals...
36
6K
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
800
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
981
957
LUV2BHATED
LUV2BHATED
BRONX NY
djman37
