Port design question...
  • 2
sabrex15
I've got a '93 Buick Regal, the back seat has an armwrest which folds down and has a plastic cover between the trunk and the backseat (very easy to make the trunk accessible) I was thinking of making a box that has 1 big port from the box to where the armwrest folds down.
Would this even work?.. has it been done?... I've got 2 JL W0's for the project..
yeah, it would work but the arm rest would have to stay down. I say build the box to fit in the trunk and them make a port from the trunk to the cab using that spot. atleast that way closing it wouldnt mess up the tuning of your box
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
916
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
643
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
800
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
770
sabrex15
sabrex15
Huntsville, AL
pburt
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
