Pops from speakers.
Cieprus
Hi, Im running Infinity Kappa's 693.5i, there rated at 110 RMS...
Now I have a rockford fosgate 75x2 amp pusing them.
So why do I get pops at max volume? If my HU is rated at 25rms and 45 max, does the max volume mean max power from HU??? And still, My gains on the amp are all the way down, so why am I getting pops??
I hate RF
Yup
35-22,000 Hz
2-way external crossovers (18 dB/octave, 3,500 Hz high- and low-pass)
recommended power range 2-110 watts RMS
peak power handling 330 watts
Ya i copy and pasted, im soo tired.
Originally posted by Cieprus Hi, Im running Infinity Kappa's 693.5i, there rated at 110 RMS...
I hate RF
you said the amp was powering them---- so why do you refer to the HU output? --- you did you use high level inputs or something???
I use the RCA's for my rears??? They are powered right???
Or is it just the amp's power on them??
Are you saying the RCA's from my HU are not powered at all?
Thanks
Originally posted by RangerMan Subs pop at times when being overpowered, and/or bad settings w/ the gains...I'm not sure if that is your case though.
I am also experiencing popping. It happens on the peaks of loud songs if the gain is set too high. The thing is, I honestly believe that this is happenning way before the amp clips and way below the rated power of the subs. I'm hoping it's something in the installation that I can fix. What are the chances?
p.s. See sig below. The USX amp can do 160 W X2 bridged, and my RMB8's are supposed to handle 175 each. I have to limit the amp to about 60 watts / ch if I don't want any popping //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Originally posted by maylar I am also experiencing popping. It happens on the peaks of loud songs if the gain is set too high. The thing is, I honestly believe that this is happenning way before the amp clips and way below the rated power of the subs. I'm hoping it's something in the installation that I can fix. What are the chances?
This shouldn't be happening...when the subs are pretty much gone, they continue to pop even when being powered correctly. Your subs might be partially blown. How old are they??? Are you the orignial owner???
Originally posted by stangsounds youre probably bridged at 2 ohms //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Naw...should not make the subs pop...the amp would be hot.
check your ground if your not getting a good ground if your ground is not good you could be having energy splurges and at higher levels the more the power the more the pop what is your head unit grounded to did you use the factory or did you make your own how are your amps grounded:nono:
Originally posted by RangerMan This shouldn't be happening...when the subs are pretty much gone, they continue to pop even when being powered correctly. Your subs might be partially blown. How old are they??? Are you the orignial owner???
Brand new. I put a 50 Hz test CD in the deck and a 'scope and DMM on the amp to set the gains. When I got up to about 16 vrms (64 watts) they "buzzed", probably the rear deck vibrating. I stopped there. Then when I played some music, they popped on the peaks so I had to back off even more. They're not loud at all... in fact the Infinity 6X9's are just as loud on only HU power. I need to get more power to them somehow.
Originally posted by maylar Brand new. I put a 50 Hz test CD in the deck and a 'scope and DMM on the amp to set the gains. When I got up to about 16 vrms (64 watts) they "buzzed", probably the rear deck vibrating. I stopped there. Then when I played some music, they popped on the peaks so I had to back off even more. They're not loud at all... in fact the Infinity 6X9's are just as loud on only HU power. I need to get more power to them somehow.
When you turn the volume up, does the sub fade out???
Originally posted by RangerMan When you turn the volume up, does the sub fade out???
Nope. Keeps gettng louder up to the point where it starts popping. Only good thing is the Kickers at least go to 30 Hz, so they're filling the void for the bottom end but no where near loud enough.
This weekend I'm gonna take the RMB8's out and mount them to an MDF plank and see if I can get them to take the power they're supposed to. I'm curious to find out if it's the speakers or the installation that's lame.
Cieprus
Cieprus
Nashua
chris229
slater
    Oct 4, 2025
    Oct 4, 2025
