Hosted
Sitting here shaking my head knowing I messed up but want to confirm with you guys. Just put in a Lanzar Opti2000D amplifier that is rated at .5 ohm. I have dual 1 ohm subwoofer and when wired in parallel and showing .8 ohm on my Fluke DMM. Using 1/0 power and ground into amplifier and have triple checked all connections. Extra battery in trunk. Big 3 has been done with 4 gauge I already had while I wait for the rest of my 1/0 to come in. I have 130 amp alternator which is on the list to get replaced soon as I get the funds. Voltage gauge is wired up back at the amp so I could watch it because I knew the amp would draw to much power wired that low. My oscilliscope is going to be here tomorrow so I left bass oh HU set at 0 (ranges from -10 to 10) and never turned volume over 2/3. Amplifier gain is set at approximately 25% while waiting on oscilliscope.
This morning I was playing with some bass heavy songs I downloaded last night. I turned the HU to 2/3 volume to see how it sounded. Voltage started at 14 and was dancing around 13.5 but got to a part of the song where bass got very heavy for a while and it dropped fast and I saw it hit 12 so I turned the volume down to 0 extremely fast and a line went across my volt meter for a second followed by the pop and smoke show. All fuses are fine and it never went into protection mode. The power supply on amp still power up and runs fans but I'm guessing it's toast. I'm sure my voltage meter is not very fast so I'm guessing it got much lower before it showed the 12v. I've only had it in for a few days now and only saw it go down to 12.5v once before going back up. Do you think it was voltage or something else? Lanzar said I can replace or refund so I'm trying to decide whether to buy a better amp rated at 2 ohm or replace it and get my alternator asap. Any help other than telling me I'm an idiot which I'm already aware of is greatly appreciated. Thanks guys!
