Polyfill! does it realy work?
nice' i'll post result once that expensive operation is finished //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The first thing that comes to mind with Polyfill is to add
it to an enclosure and TRICK the woofer into thinking
it is in a larger enclosure...
first of all a Sub Woofer is NON LIVING...it does not think
it is in a larger enclosure when polyfill is added..
I have experimented with Pollyfill in all sorts of enclosures
and these are my findings
Polyfill does 3 things
#1..
Polyfill dampens the echoing sound waves inside the enclosure...
a thin layer on the walls of an enclosure will reduce the amount
of soundwaves rebounding off of the inner enclosure walls and
it also reduces the amount of soundwaves rebounding off of the
back of the woofer cone...
in a perfectly square enclosure it will
reduce the amount of standing waves...
used correctly it will deaden the sound between the notes
creating a smoother sound from the front of the cone
#2...
Polyfill eats up inner volume...if your enclosure is too small and
you add a pound of pollyfill you will reduce the inner cf3 of the
enclosure and the output and low end extension will decrease
doing the exact opositte of the desired effect
#3...
Polyfill traps heat...it works like insullation
in high power systems adding polyfill will
increase the inner temperature of the enclosure..
this is not good for those who like to pound their subs
hard for long periods of time
I have read articles by Richard Clark in Autosound Magazine
regarding on pollyfill and his comments were there was little
or no audiable difference by using pollyfill in an enclosure
this subject is highly controversial and is surrounded by
many different opinions
these opinions are my own...done with several different types
of enclosures and woofers....
there is no substitution for a properly made enclosure....
here is an article by Richard Clark (from Autosound Magazine)
Richard Clark11-14-2002, 12:07 PM
guys--------stuffing the box with polyfill has the effect of converting SOME OF THE PRESSURE CHANGES INTO HEAT-----adiabatic means the the system would be loseless regarding applied energy and really does not relate to pressure specifically-------with any spring (except a textbook perfect one that does not exist in nature) there is at least some isothermal effect------the air in the box is a reactance (spring) and when energy is applied (the spring is squeezed)------ the spring returns the stored energy when released------since there are no perfect springs all the energy is not returned-----the energy is lost as heat when the material in the spring flexes------this is no different with an air spring in a woofer box or a car suspension spring------the polyfill makes the box a more lossy system by absorbing SOME OF THE ENERGY by converting it to heat-----that leaves less spring pressure to push on the speaker cone------but the system by no means becomes totally isothermal (meaning all the energy would be converted to heat)-------if it were the box would behave like it was an infinitely large resistance and would resemble a transmission line-----------bottom line?????-------like i have posted about a jillion times-------the effect is subtle at best and does not make a very large (if any) audible difference..........RC
[ November 14, 2002, 12:09 PM: Message edited by: Richard Clark ]
did anyone read that this is a ported box? last time i checked adding poly won't do squat in a ported box. just sealed.
i don't see a lot of people using it in ported box, neither in big box (4.2 net is higher than recommended for type r)
that's why I asked the question
So overall, little better sq, but low end boost questionnable?
Eat internal volume? No good //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I guess it only happen when there is too much polyfil.. since it's first known use is to "expand" the inner volume
Any more experiences? Comments?
Isn't supposed to help with the heat dissipation? The same way deadener absorb vibration
Polyfill use in a ventend enclosure is to reduce standing waves, and it DOES change tuning - typically increases it, so I dont think this is something that the OP should be doing.
Poly fil is cheap, just try it and if you like it great, if not, then you didn't waste much money. You are the only one that can determine if you like the results or not.
or a teddy bear //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'll do it then post result tommorow
Poly fill traps the rear wave of the speaker keeping it from reflecting back and hitting the cone. This reduces 2nd order and 3rd order distortion...
38
454
10
Xprime4
****in' canadian
Xprime4
Quebec, Canada
Notloud00
    May 31, 2024
    May 24, 2024
