polk audio
xtully
Hey guys, I have a Honda civic to start, I just installed polk, audios db 6501 comp set. I have a cadence zrs 1501 two channel powering them. So my problem is I have like no mid bass.. the amp is set at 80ish Hz crossover hpf, no Sa, bassboost, or anything else on. I was going to try turning my hpf down. The speakers are clear and crisp just no mid section. Also doors are not sealed or reddened properly (reason?)
problem fixed.. I had it on high pass! switched to full range and it solved that issue.. but at 80 hz should I hear subwoofer dropping off and my comp set kicking in? also for the gain I used the formula sq root of 4x150 but should i multiply this by 2 since there are 2 midbass comps/tweets
I hate how neither of my amps have accurate dials for their filters.. ******* pisses me off hardcore
xtully
xtully
Akron, Ohio
xtully
