Plz Help
  • Thread starter Riven02
  • Start date
  • Replies 1
  • Views 505
    Participant list
R
Riven02
Guest
i just sent my jl 500/1 back for repairs and i borrows a mtx amp but they both have the same prob so it must be my wiring ........the lights on my jl would come on and no sound though while the mtx has no light or anything uness i touch the remote to the 12v input..........but i dont seee how its not getting power from my battery cause i have 4 gauge wire strait in from the battery and the fuse looks good.any help?? plz im stumped
In this situation it is best to trace all your wire hookups. Remote turn on ,is it a big enough wire?how many amps are ran off of that turn on lead? If more than one some times its best to install a bosch relay to give the amps plenty of juice to turn on. Check your RCA,s for damage or poor connection at the amp and back of head unit. Check all fuses and the power wire. Break out the old test light for that.And of course check all your grounds. Just some idea,s. Good luck...........
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
If you haven't located the short...reconnecting everything can go the wrong way at the worst time...
26
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
786
Guest
