plywood box is back =]
once again douche, i didnt spend anything on the materials. and yes i know mdf is better if u read the first thing i said i made the box just for some sound. not for a permanent install. but people on this forum dont understand what temporary means...
Even temporary, it should have had some internal bracing added. Especially if/since you knew you were using inferior materials. About a dollar's worth of 2x4's would work for a couple braces. Or a left-over piece of that osb with some holes cut in it. The neighbor's mailbox post. Your dad's old drum sticks screwed together. Almost anything really.
When you have a box with excessive wall flex, a couple bad things can happen. Internal volume will change. And if flex is bad enough, separation can occur allowing unwanted air to enter/escape. Both of these problems will alter system tuning. Frequency response will become erratic, and in the case of wall separation, unwanted and usually audible noise will occur. Your system is still getting loud, your doors are still vibrating, but that doesn't mean bad things aren't still happening. I get the impression you feel this video proves something, but Im not sure what you think it proves. The box is weak, you know it is. Im glad you are happy now, but save up a few bucks and redo the box with mdf AND bracing. You'll be even happier.
And dont forget to bolt the box down securely, for system performance as well as safety. Ive always found it funny, when I tell people bolting the box down is a real safety issue, they say the work isnt worth the risk. But when I tell them it also improves the performance of the stereo itself, they decide its important to do.
point theyre trying to make if you spent money or not....a slab of mdf will run you less than $50. for you to take the time and effort to build a box out of ply wood knowing its temporary and you'll upgrade later is a pointless waste of time but if thats all you got is time then by all means have fun with construction practices. spend a small amount of money to get it done right the first time and have it complete. that box is flexing wayyy too much dude, tighten up with mdf and reap the rewards...
and i will as soon as i get a job or come across a load of money
it has a sh!t load of bracing inside of it. and yes i know all of what u said. i know the box is flexing and i know its bad but for now it will do and it sounds **** good for what it is made of. and the video was to show that the box flexes and that it is a horrible box.
OP is fully aware that his box lacks integrity and is acknowledging the fact that MDF would be superior.
The fact that he cannot afford to make a sufficient MDF box is not exactly a great reason to bash him. Just means he has to find time to work. Probably means he is either a student or busy with other important matters.
As long as he is fine with how it sounds, and is not claiming that plywood is the new best material, this thread should be used for what it was made for. And that is enjoying a flex vid using a humorous box.
The b!tching should have stopped in the 1st thread about this lol.
Back to you, man.
Full of Fial right here...
Fial for having a Honda name, with a Jetta car
Fial for the sub choice
Fial for the box design
Fial for he box materials
Fial for putting this in the wrong section
FIALLLLL
actually his shit is slamming pretty **** hard, hes just a dumbass for choosing plywood in the first place.
As long as he is fine with how it sounds' date=' and is not claiming that plywood is the new best material, this thread should be used for what it was made for. And that is enjoying a flex vid using a humorous box.
Back to you, man.[/quote']
wow someone on this forum who does have a decent head on there shoulders and is not into talkin mad crap about ever little thing that is wrong.
ty
kwitcherbichin
kwitcherbichin
stantonsburg, nc
kwitcherbichin
