Please help
Olliejcp
Kendal
This is my first time ever doing this as I have only just bought my first sub so I know absolutely nothing about this. So I have bout a Sony xplod sub but have no clue what amplifier to buy as the RMS is 350watts and the peak is 1200 and anyone advise on what to buy? I'll add a photo of the subs full specifications. Thanks in advance.
Start by going to a car audio equipment website, and look for an amplifier that will handle your needs. Best buy, Crutchfield.com and amazon are some suggestions. You can email Crutchfield support with your sub specifications, and they will send you suggestions. Also Search this forum for good brands to purchase. Just a suggestion.
879
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
874
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Olliejcp
Olliejcp
Kendal
