please help would like to get it done today
You need a LOC. You can get a cheap one but you will have to deal with the factory EQ and low end cut off. Or you could get a Audiocontrol LC-2 and it will override it. That is your best bet. Look up the LC-2 on their website and it will show you what it does.
I don't know exactly, speakers are 2 dual coil pioneer ts-w310d4.
The wiring kit came with battery positive and negative cables, an rca cable, a cable that's exactly like the rca but without the rca endings, and a thin blue wire. I installed everything except the rca, one that looks like it, and the little blue one so pretty much just power cables. Are they two versions of the same cable and I'm only gonna use one?
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
952
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
noushutup
noushutup
Canada
noushutup
    May 16, 2024
    May 16, 2024
