Please help with my setup
chrisr6
Hi, i recently fitted 2 pioneer TS-W307D2 1200W subs in an inphase double box with a Juice JA690 2400W 2 channel amp and a sony gtx-50ui head unit. The left sub in the box is rattling like hell. If i put pressure on the sub it stops it rattling. The amp level is on about half and also the bass boost is about half with low range up full. Iv put a couple of jumpers round the back of the box and its helped quite a lot but still can't get the subs pounding how id like without massive rattling. Any suggestions? Regards
Chris
Yes they are all in securley, well pretty sure of it. Also my Dad used a multimeter to test + and - so that should be wired up properly
i had a problem like this a few years ago i had to remount the sub 3 times before i relised that when i put presure on the sub i was also puting presure on the box at the same time ..
Is it ok to disconnect 1 sub from the amp and just have 1 sub running off 1 channel? I heard maybe you have to have all channels connected to something
chrisr6
chrisr6
London
chrisr6
