please help with info on sub and amp
Ive got a 4500w ssw starsound sub and a 4400w starsound monoblock amp can these two work or is the amp too small??? Because my amp gets really hot even only after playing it 15min on 75%.
no idea what brand that is, but what are they rated for RMS wise each? just try to get an amp with an output matching the power which the sub can handle
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Louwkie7777777
Louwkie7777777
Johannesburg, SA
fordnut78
    Jun 1, 2024
    May 31, 2024
