Please Help....Need to know wiring on a 2 channel amp..need help fast
  • 4
Miller
I have a 2 channel amp and my friend wired my 2 4 ohm DVC Type-R's both in series. The amp I have does 200 RMS x 2 @ 2 ohms. I'm a little confused on if he wired this right or if I should re wire it. He wired both of my 4 ohm DVC subs in series to each channel. Doesnt that make it 8 ohms at each channel?? when the amp says it does 200x2 at 2 ohms does that mean I should wire both channels at 2 ohms or combined the channels should equal 2 ohms. Thanks
I've seen the sticky...but I guess my question is....When an amp says it does 200x 2 @ 2 ohms does that mean each channel should be wired to a 2 ohm load?? So if I have 2 4 ohm DVC subs both of them should be wired in parrallel to make 2 ohms into each channel...right??
Miller: I had the same situation. If you want your subs hooked up to your amp for a 2-ohm load, you have three options:
1) Wire each sub's VC's in parallel for 2 ohms and run each one from a separate channel on the amp (not bridged)
2) Wire each VC in parallel (2 ohms) then put both subs in series for 4 ohms total and wire to the amp bridged
3) Wire each VC in series (8 ohms) then parallel the two subs, which also gives 4 ohms, then to the bridged amp.
I used option 2. It doesn't matter though, good luck.
Originally posted by Miller I've seen the sticky...but I guess my question is....When an amp says it does 200x 2 @ 2 ohms does that mean each channel should be wired to a 2 ohm load?? So if I have 2 4 ohm DVC subs both of them should be wired in parrallel to make 2 ohms into each channel...right??
That's correct.
Ya...I ended up using Option 2 up there. I bridged it into a 4 ohm mono load. It sound SOOOO much better and louder. Thanks man, later
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
983
Or you can buy a bypass https://lljcustoms.com/products/2018-2021-gm-gmc-factory-anc-bypass-select-vehicles
979
Miller
Miller
Chicago,IL
Miller
