Please help me, First Amp Install
Hey, I have 12 gauge speaker wire, but apparently there are no 12 gauge terminals that fit my speakers; What do you guys think about using a 14-16 gauge terminal and crimping it to my 12 gauge speaker wires??
Or my other option is to crush the 12 gauge terminals to the smaller speaker male terminals
What should I do?? Will either choice have an effect on the sound quality?
In order to get the speaker wire into the door I had to drill a hole into the frame of the car. The jacket over the speaker wires was pretty thick, so I didnt worry about a grommet, do you think I should hot glue it there or something so it doesnt move around?
Uhh, no you for sure need a grommet. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
ahh but it was hard enough getting the wire through the hole, theres no way in the world i'll be able to get a grommet into there. The positive/negative wires both have jackets, then theres a jacket over both the wires themselves...
a grommet protects the wire + it waterproofs the hole..
If I get some silicone stuff I can apply it to the hole to water proof it (and prevent the wire from moving), do I really need a grommet or do you think the 2nd jacket is enough to protect the wires?
I love the multi-quote feature. Saves me from repeating myself. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
The amp I bought came with some fuses in a bag, but it looks like theres already fuses in the amp //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Do amps usually come with extra fuses? Or do I need to put them in there somehow?
Also, I have everything except the speaker wire to the back speakers set up!
I have a harness for my headunit. Theres a white/blue wire on one end, and another white/blue wire on the other end that leads to my stock wiring. Do I disregard the 2nd end, and connect the white/blue wire to my remote wire I ran to my amp? (white/blue = remote amp turn on, on the instruction sheet for the harness)
Lastly, I can't fit a grommet inside the holes i drilled into the doors... Whats going to happen :X
Not much....
make sure you have a fuse inside the amp or it will not turn on, make sure you have a fuse up front at the battery.
pull out the speaker wire, drill a slightly larger hole using a step up bit, insert a grommet, run some spilt loom tubing and seal it with silicone.
Everything is installed and nothing has exploded yet!
Now I have to adjust it the amp settings.... Any suggestions?
My front speakers are 2 ohm and can handle 60 watts rms (Infinity Reference 6822cf), the back speakers are 4 ohm and can handle 80 ohms rms (JL Audio cr690cx)
The amp is 75 watts RMS @ 4 ohms.
Its suposedly not built for 2 ohm speakers, but the guys at crutch field said the infinity reference speakers would probably be fine? so according to my calculations...
there should be a 2:1 ratio between the the 4 ohm 75 watt speakers and the 2 ohm 60 watt speakers.
So I'll set the power of the front speakers at half of the power of the back speakers, Right?
I have the input for both sets of speakers at half way up (hu @ 100% volume)
The infinity speakers can go up to 3/4 input until they distort, but when I turn the JL Audios input up past 1/2, the amp shuts off? (protective mode?)
I read the trouble shooting manual that came with the amp, and it said it may be because of a short in the wiring.
What is a short? And what could possibly be the problem? (if it even is a problem...shouldn't the JL audios imput be 2x higher than the infinities though?)
btw, I soldered the terminals onto the speakers (because they were slightly too big) but they're tight to the pull now. I also put bare wire into the amp itself because the spade terminals I got didnt fit in it.
SocialStealth
New Jersey
SocialStealth
Mike Mccabe
