Please help me find where to ground... *PIX*
cha.... the freakin alt is on the bottom of the car.
welcome to the club except my skidplate, front drivetrain and crossmember(s) all make it harder to get to from the bottom. No big 3 for me.
lol that sux tundra...
as promised pix of hte alt location:
these are shot from underneath the car
and from the top:
at least its semi easy to get to the alt from the bottom.
The alt grounds it self through the metal of the engine. As mentioned in the big 3 trhead, find your old ground points and add to them. Or find a non-essential bolt on your engine and ground from that.
okay cuz theres too many wires and tubes goin into the chassis to figure tout what goes to what.
which part of the engine do i wire? sorrry i **** at automotive stuff.
The alternator is already grounded to the engine block. It helps if you also ground it to the body of the car. Unloosen the bolts that mount the alternator to the engine block and put the ring terminal on it (Instead of taking the bolts all the way out, I just clipped a small piece off the end of the terminal and slid in onto the bolt). You may also want to do a little sanding. Now, connect that ground to a bare metal spot on the body.
AH i getit. thanks!
or if you want to eliminate that wire you can just run a 2/0 piece of welding cable from where the alt mouts to the back where your batt/ amps are.... thats what i did in my rex b/c i didnt wanna do what yoru trying to do
em run wires through my car?? //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif :crying: //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif :crying:
i hope you meant the batt under the hood.
i ran a piece of 2/0 from the ground of the alt to the engine to the back where my amps and spare battery was located
oh i was just gonna run a piece of 1/0 from my engine to a ground. is it possible to use my starter battery like that? engine block (since my alt is already groudned by the engine) to the negative on the battery or the ground where the negative lead is?
if your trying to solve dimming it shoudl work by grounding from there, but i really do not no... i know running it to the back helped tremedously for gettin power from the amp
gave me the greatest potential difference
flakko
Veteran (my butt)
flakko
So Cal
lilmaniac2
