Please help me choose
Well, from what most sources have been saying; the IDv3 series is actually a little louder and a little better sounding (SQ wise) than the current IDQv2 series. The IDQ's are undergoing a makeover as we speak I believe.....or atleast will soon. Don't know when the IDQv3's will be released though (could be quite a few years.....we're still waiting for an IDOne and a 15" IDMax).
I guess it all depends on your amp. If you have a nice amp that can handell the lower resistance than go ahead. You did say your more into SQ though I prefer a higher resistance for SQ especially with cheaper amps( I don't know what your running). You could run a DVC 4ohm at 2 ohms and than if you find its too sloppy try running it at 8ohms. I am not famillaire with those subs though.
I havent bought the amp yet. Most likely a 1000 watt amp (500 a sub).
in order for you to choose what voice coils (dual 2 ohm or 4 ohm) we need to know what amp you will use. 2 dual 4 ohm subs can be wired at 4 or 1 ohm making an amp that produces 1000 watts rms at 1 or 4 ohms a good pick. 2 dual 2 ohm subs can be wired at 2 ohms or 0.5 ohm. most amps aren't stable at 0.5 ohms. i would say get dual 4 ohm subs because there are plenty of amps available that produce 1000 watts rms at 1 ohm
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
Aaronsmity
Aaronsmity
Houston, TX
iceteebone
    May 31, 2024
    May 24, 2024
