Please help me choose the best speakers
mio
Hi i will need to upgrade my rear speakers jl audio c5, , here is the specs of the system p99rs , front morel virtus nano 602, amps 3x mosconi pico 2 2x 80w., 1 for low,1 high ,1 mid, + sub eton res flat,rear jl audio c5
so far here are the things which i have choosen, to replace jl audio,
adrian speakers ,
A165.g Tiefmitteltöner
16,5 cm DIN Tiefmitteltöner mit extrem stabiler Vollaluminiummembran
Butyl-Gummisicke
anthrazitfarbener, hochgedämpfter Aluminium-Gußkorb
rundum belüftete Zentrierung
mehrfach gebohrte Polplatte für optimale Wärmeableitung
vergoldete Anschlussterminals
schwarze Staubschutzkappe
extrem lange 25 mm Schwingspule (4 Ohm) für grossen X-MAX (±4mm)
optimierte Zentrierspinne für langen linearen Hub
Kupferpol-Kapsel zur Linearisierung des Impedanzverlaufs
Einbautiefe 6,5 cm
Gesamttiefe 7,3 cm
Resonanzfrequenz 80 Hz
linearer Frequenzverlauf 80-5000Hz ±3db
Schalldruck 90db 1W/ 1m
Belastbarkeit 80 Watt Sinus/130 Watt Musik
Blam signature series https://www.blam-audio.com/wp-content/uploads/2019/07/S-165.300.pdf here are the specs please take a look into speakers only, i also use cross overs from my p99rs so i dont need tweeters or cross overs.
and last option as speaker
is this one BRAX Matrix 6.1
BRAX Matrix 6.1
High-End 165 mm mid/bass, recommended for deep bass
RMS power handling 120 Watts
Max. power handling 170 Watts
Impedance 4 Ohms
DC resistance 3.4 Ohms
VAS 13.49 Liter
Qts 0.58
Sensitivity 88.6 dB
Resonance frequency 46 Hz
Diameter 167 mm
Installation diameter / mounting depth 143 mm / 64 mm
, what do u think
which one of these are the best and better than jl audio c5.
Unless it's a sub you don't need to waste money on rear speakers . When you go to a theater or concert where do you want your sound ? In the he front . Any rear speaker with power is gonna pull your front staging to the rear . You want to sit in your vehicle and listen to your music like your at a theater or concert not walking out the door and leaving it all behind .
mio
mio
EUROPE
Louisiana_CRX
