Please help me choose the best speakers
  • 2
mio
EUROPE
Hi i will need to upgrade my rear speakers jl audio c5, , here is the specs of the system p99rs , front morel virtus nano 602, amps 3x mosconi pico 2 2x 80w., 1 for low,1 high ,1 mid, + sub eton res flat,rear jl audio c5
so far here are the things which i have choosen, to replace jl audio,
adrian speakers ,
A165.g Tiefmitteltöner
16,5 cm DIN Tiefmitteltöner mit extrem stabiler Vollaluminiummembran
Butyl-Gummisicke
anthrazitfarbener, hochgedämpfter Aluminium-Gußkorb
rundum belüftete Zentrierung
mehrfach gebohrte Polplatte für optimale Wärmeableitung
vergoldete Anschlussterminals
schwarze Staubschutzkappe
extrem lange 25 mm Schwingspule (4 Ohm) für grossen X-MAX (±4mm)
optimierte Zentrierspinne für langen linearen Hub
Kupferpol-Kapsel zur Linearisierung des Impedanzverlaufs
Einbautiefe 6,5 cm
Gesamttiefe 7,3 cm
Resonanzfrequenz 80 Hz
linearer Frequenzverlauf 80-5000Hz ±3db
Schalldruck 90db 1W/ 1m
Belastbarkeit 80 Watt Sinus/130 Watt Musik
Blam signature series https://www.blam-audio.com/wp-content/uploads/2019/07/S-165.300.pdf here are the specs please take a look into speakers only, i also use cross overs from my p99rs so i dont need tweeters or cross overs.
and last option as speaker
is this one BRAX Matrix 6.1
BRAX Matrix 6.1
High-End 165 mm mid/bass, recommended for deep bass
RMS power handling 120 Watts
Max. power handling 170 Watts
Impedance 4 Ohms
DC resistance 3.4 Ohms
VAS 13.49 Liter
Qts 0.58
Sensitivity 88.6 dB
Resonance frequency 46 Hz
Diameter 167 mm
Installation diameter / mounting depth 143 mm / 64 mm
, what do u think
which one of these are the best and better than jl audio c5.
Unless it's a sub you don't need to waste money on rear speakers . When you go to a theater or concert where do you want your sound ? In the he front . Any rear speaker with power is gonna pull your front staging to the rear . You want to sit in your vehicle and listen to your music like your at a theater or concert not walking out the door and leaving it all behind .
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
842
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
849
mio
mio
EUROPE
Louisiana_CRX
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
