PLEASE HELP i'm new at this
  • 3
barto
I'm new to car audio, so PLEASE help me out
ok this is my cd player -->> http://www.sounddomain.com/sku/SONCDXL300?ref=deal
and my setup will look something like this (this is for my 95 civic):
(2) ORION XRT's 12's
http://www.dealtime.com/Product/Product/1,2436,422-1-1-1-36033,00.html
US ACOUSTICS 2150 AMP just left and right inputs (doesn't have preamp) this amp is used for the subs--->> http://www.sounddomain.com/sku/USAUSX2150?ref=deal
ORION 100.2 the one for my 6 1/2 speakers in the back
http://store.yahoo.com/advantage123/orioncs1002.html
I was just wandering if I could hook more than one amp up to that cd player and if not, how could I make it fit like 2 or 3 amps
is that a good system?
thank you
well it only has one set of preamps but all you need to overcome that is a set of Y adapters....which would allow you to run more than one amp....and for that amp that doesnt have the preamps...just use the rear inputs for that amp....kinda pointless to have rear fill unless you prefer it.....most prefer the front imaging....good luck...any more questions i'd be more than happy to help....
you gotta watch spliting the RCAs to many times as this with cause the load on the pre AMP to be TOO LOW burning it out. It the same as hooking up too many subs to a AMP in parrallel causing TOO LOW of a load. Best to get a X-over with multiple outs or a line driver of some type
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
barto
barto
Pittsburgh, PA
barto
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
