Please help - alternator problems
  • 7
Is there a point to getting 2/0 welding? Or should I just go with 1/0? I've heard that 2/0 is more like car audio 1/0.
Go with 2/0. It's the same size as CA 1/0 and then you won't have to upgrade again if/when you upgrade power.
For 40 cents more a foot, I would.
That's what I'm thinking. I might as well.
Sent from my SM-G920V using Tapatalk
Thats just size wise. However if you condense all the copper in the wire, car audio 1/0 ofc, it weighs just as much as welding 1/0. Car audio wire does not follow AWG standards. However, bigger can never hurt, especially with our upgrade tendencies.
Sounds like you have low rpm and it's turning on once you get to a high enough rpm? Did u get a hairpin?
Any cheap fixes to that other than sending the alt back in for a mod? So far, ive just manually turned up my idle rpm and its okay, but wondering if theres another solution.
I don't see myself upgrading for a bit, I've had this setup almost a year and no intentions of upgrading for a while. I am doing mids and highs first and then cleaning up everything before I do bigger amp and subs.
I'd do the mini dsp and get the software for it. You'll be amazed what can be done with proper time alignment and crossover+proper slopes. Your current head unit has zilch processing capabilities. That minidsp can be for theatre or car audio depending on how they ordered it, there's a DC power option.
I have the DC power option.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Savackz
Savackz
GA
Jeffdachef
