Trepkos
I just got done setting my gains with the DMM, my main issue and area of concern is the subwoofer and the Hifonics Bxi1606d amplifier. The component set is working and sounding fine and so is the Sundown SAX 100.2 amplifier. The Hifonics amplifier and subwoofer on the other hand are just being a pain in the *** to get sounding decent.
To give you all the information I can on the subject we'll start here. I want that 15" Fi Q sound that we see and hear in videos, the smooth rumbling bass on all frequencies, well-reproduced, very loud, and sounding very good. To achieve this I have done the following.
I had the following set on my amplifier and head unit.
Amplifier:
SSF: 25hz
LPF: 80hz
Phase: 0
Bass EQ: 0
Bass Boost: 0
Gains: Adjusted with a DMM at their peak playing frequency to do 34.6volts(1200watts@1-Ohm)
Noted with a DMM, the impedance load on the amplifier is shown to be 1.5ohm's according to the DMM staggering at 1.3ohms every now or then. The DC voltage being sent to the amplifier is steady at 14.4volts.
Headunit:
Subwoofer Output = 15/15
Volume: 26/35
Volume Offset: 0
Loudness: Off
Crossover Frequencies For The Subwoofer is
60hz with a -12db/octave slope.
I decided to use this song as a test song, "Put On" - Young Jeezy.
Well that, yielded no real decent results, the subwoofer sounded fine with no clipping and no distortion but also wasn't very loud at all. Heres a video of it.
http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=defaultsetup.flv
We will name that as the default setup, no enhancements, just pure gain and frequency tweaking. Shortly after that I decided max out the filter settings on the amplifier, setting the Sub-Sonic Filter at 15hz and the LPF at 250hz. And let the cross over settings on the head unit take over. There was a distinct increase in sound and performance from doing this, but nothing too great.
So a little satisfied with that but still not impressed I decided to play a game to see how to achieve that 'sound" that I defined above and by doing this I played around eight different setups and recorded them with a video camera so you can see the performance too.
First Setup
Amplifier Gains = Maxed
Volume Offset = 0
Loudness = 0
Remote Bass Boost = 0
Bass EQ = 0
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=Setup1.flv
Second Setup
Amplifier Gains = 3/4
Volume Offset = 3
Loudness = 0
Bass EQ = 0
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=Setup2.flv
Third Setup
Volume Offset = 0
Loudness = On
Remote Bass Boost = 1/4
Bass EQ = 0
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=setup3.flv
Fourth Setup
Amplifier Gains = 1/2
Volume Offset = 0
Loudness = 0
Remote Bass Boost = Full
Bass EQ = Half
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=setup4.flv
Fifth Setup
Amplifier Gains = 2/3
Volume Offset = +5
Loudness = On
Bass EQ = 0
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=setup5.flv
Sixth Setup
Volume Offset = 3
Loudness = On
Bass EQ = Full
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=setup6.flv
Seventh Setup
Volume Offset = 3
Loudness = On
Remote Bass Boost = Half
Bass EQ = 0
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=setup7.flv
Eight Setup
Volume Offset = 5
Loudness = 0
Remote Bass Boost = 1/3
Bass EQ = 0
Video: http://s286.photobucket.com/albums/ll101/Trepkos01/?action=view&current=setup8.flv
If you think you can really help me on this subject, I have MSN, AIM, and Yahoo and would really appreciate the help.
Amplifier:
SSF: 25hz
LPF: 80hz
Phase: 0
Bass EQ: 0
Bass Boost: 0
Headunit:
Volume: 26/35
Volume Offset: 0
Loudness: Off
First Setup
Volume Offset = 0
Loudness = 0
Bass EQ = 0
Second Setup
Volume Offset = 3
Loudness = 0
Bass EQ = 0
Third Setup
Volume Offset = 0
Loudness = On
Bass EQ = 0
Fourth Setup
Volume Offset = 0
Loudness = 0
Bass EQ = Half
Fifth Setup
Volume Offset = +5
Loudness = On
Bass EQ = 0
Sixth Setup
Volume Offset = 3
Loudness = On
Bass EQ = Full
Seventh Setup
Volume Offset = 3
Loudness = On
Bass EQ = 0
Eight Setup
Volume Offset = 5
Loudness = 0
Bass EQ = 0
