Pioneer?
  • Thread starter Unregistered
  • Start date
  • Replies 17
  • Views 4K
Yeah they are svc subs but you get two 8 ohm subs wire them in parrelell like i did and that keeps a four ohm load on your amp and still pushes the subs to thier max nearly and keeps the amp off a 2 ohm load like you would get with 4 ohm speakers. And with the amps i dunno if planet audio amps have a xover (probally do) but on Rf you can set it where its all bass or you can get sound out of it too. With a flick it will thump. Those kickers do have awsome sq put it in a ported 1.25 box and you have awsome sound that will thump good, clean, tight, base. But if you are wanting a dvc sub yea i would go with the comp vr they are **** good subs but more $$$$ But you get one 15 and that should be close to the 2 12s but the 2 12s are still cheaper so your best bet is go with the 2 12s casue you cant afford 2 15s or just get 2 15 kicker comps but i like 12s best of both worlds 15s dont have all that great sq just alot of bass. So i dont really care which amp you go with cause alot of good amps but i am just saying you will probally get a Rf alot cheaper than planet audio and i havent heard anything great about PA but maybe they are ok just go with that setup and i will tell you you'll be pleased. And another good amp is a kenwood 729s 600 watt amp i have a friend that had the same amp and hooked it up to my subs i thought it pushed as good as the Rf 250.2 and then some and is alot cheaper only like 129 new on e-bay. So whatever you choose just go with what you want and what you like.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Patrick
the class d's are only one channel, with no high pass filter, and i own it, not won it, i wish i had won it. for 800.00cdn it is a **** good amp.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
332
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
757
Guest
taylor
    May 16, 2024
    May 16, 2024
