pioneer ts-w254c
  • Thread starter Car Nut
  • Start date
  • Replies 4
  • Views 2K
  • 2
C
Car Nut
Guest
I've got 2 pioneer ts-w254c's in a sealed box. they're hooked up to an alpine mrv-T707 2/1 channel amp. I've got the amp cranked and the subs are wired in 8ohm config. They're not thumping hard at all and the gain and bass boost is almost at full. Should i wire the subs in 2ohm fashion?
Thanks
no wonder your subs are only getting half of the power they should be cause your running it in 8 ohm, if they are svc bridge them both off of your amp, if you know your wiring thats series .
thanks for your input guys!
Alpine's made for 4ohm loads and not 2ohms. I just got my wiring all messed up but it's cleared up now thanks to you guys!
really appreciate it
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
355
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
781
Guest
audiobaun
    May 19, 2024
    May 19, 2024
