Pioneer Sub Level
  • 4
Sleeklsc
Where to put it? Leave it at zero and adjust gain or max it out and adjust gain?
The lower bands on the eq are lowered heavily to save the interior speakers resulting in the gain on the sub amp needing to be raised higher. In the end I think any adjustments will have the same effect, lowering one and raising the other will have the same outcome. All artificial boost and bass eq's have been, and will forever be unused.
Typically you set the gains at 0db and adjust the sub level yo match the output of the music since some music is quieter than others, but in doing this you have to be careful not to overdrive the amp and clip the subs
yeah don't go to high on amp gain.. does that hu have xovers for speakers? if so set hp xover at 80-100hz speakers will be protected but don't boost the low freqs on eq anyway, as far as speaker gain if u have gain for each speaker i'd leave them flat or lower rears a little (so fronts are louder of course can do that with fader too) as far as sub volume on hu i leave mine at +1 and when i play rock i go to +3 but i have my amp gain set for that.. if u have remote amp knob for sub use that to raise or lower level on each song (i keep mine in my lap)
you dont need to lower the EQ bands to protect speakers from playing to low... You use a high pass filter for that dude..... Wrong tools for the wrong job.
True, and why I state, all things considered equal. There are a multitude of variants, but that foundation is where you start and build from...
18
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
Download the manual. Should be some information provided. https://manualsfile.com/product/j0s9nlrgv.html
Sleeklsc
Sleeklsc
Jeffdachef
    May 12, 2024
Brendon Jenness
    May 11, 2024
