Sold Pioneer Premier TS-W1500SPL, Sub Box
Size 10"
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll 3-Layer Fiber Woven Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil (2 x 4ohms)
Voice Coil Bobbin 4-Slit Glass-Imide
Damper (Spider) Y
Top Plate Thick 7/8" (20mm)
Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (80oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Silver Binding Posts
Specifications
Watts MAX. Music Power 1500W
Watts Nominal Power Handling 600W
Frequency Response 18Hz ~ 2,500Hz
Sensitivity 87dB
Ohm Rating DVC (2ohm or 8ohm) dual 4 ohms
mounting depth 6 3/8"
I've only run 200 watts x 2 at 4ohms to it. with the gains down. Since I knew I was selling it once my 12s were done I didnt want to push it.
as for trades I might be interested in trades depending on what they are.
ruckus
Banned
ruckus
Miami, FL
bumpn_gt
michigan born
    May 14, 2026
michigan born
    May 14, 2026
