pioneer HU won't play ipod.
alright i just tried removing the hu, it it will not budge. i dont have the keys to remove it either. i asume after u remove the outer trim, u slide somthing into the small slots on each of the hu?
yes, that is correct. I would head to an install shop and buy the "keys" to remove it.
i HIGHLY suggest you just go get the ipod ip-bus from Pioneer, it plugs into the back of the deck and you can use the deck to control the IPOD, plus it charges it for you, where-as the aux in with the mic jack will only play the thing and not charge or give you control externally.
Its what I have and it works great.
that stereo doesnt have a aux in unless u bought the cbr-10 thing that turns the blue plug(IP-BUS) on the back to rca jacks, or cbr100 ipod adapter which is not compatible with this old or a radio i dont beleive
has 2 amp outputs no inputs bro
yup needs to be on aux. by the way this hu is in a 2000 civic si...if that helps for removing info. and i wish i had the keys but the cars in pieces right now bc of trying to figure this out so im trying to find something else that ill fit in b/w to remove the hu.
it has the adapter to turn the blue plug into rca jacks that then go from a y back into a single aux cable. also the hu is mp3 ready so it should work.
I'm guessing that he has the IP-BUS to female stereo RCA adapter like I have (i don't know if cbr-10 is the model number, but it might be). Then a male stereo rca to 1/8" male stereo plug, which he plugs into the headphone jack on the ipod. that is what I have with my old Pioneer deh-p545.
OP, if I were you, i would get that headunit out of your dash and make sure everything is connected correctly regarding the ip-bus and ipod connections.
midwestdivision
midwestdivision
WI
TurdFergueson2
