pioneer gm-x962 or kenwood kac-728s
  • 2
subboxmaker
Ok currently i have a pioneer premier 10" sub that handles 400 watts rms. which amp should i buy the pioneer(380rms) or the kenwood (300rms).
I had the kenwood but i sold it to a guy cause i figured he paid enough for me to get the newer model but now i saw the pioneers for cheaper. around $130 shipped i need some advice!! Has anyone heard any good things about pioneer amps or own one?
Some advice would be greatly appreciated. Thanks.
given the two choices mentioned... i would go with the pioneer. it has a closer RMS watt rating than the kenwood. but, you could do a lot better with an even more powerful amp for your sub. some thing in the 400-500w RMS range from a reliable manufacturer. jl audio - jbl - rockford fosgate - mtx just to give you some examples.
Thanks but can i buy a bigger amp or will i blow my sub, its only supposed to handle 400 rms and 800 max, what about the kenwood 929 would that be too much power. also what kind of box do u recommend? thanks
you will want to give your sub at least its RMS watts... with no harm if you go over the rms by as much as 50-100watts rms. if you want spl then go with a ported box. if you want sq then go with a sealed box. i recomend a sealed box, you can acheive the best of both worlds (spl & sq).
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
343
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
763
subboxmaker
subboxmaker
in my house
imral3
    May 16, 2024
    May 16, 2024
