Pioneer GM-X564 opinions
Rob.
I currently have this amp. I want some opinions on its specs/numbers..
Im not really sure if its a good sounding amp or not.
thanks
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Amplifiers/Other/GM-X564?tab=B
Features:
PWM Regulated MOSFET Power Supply
Bridgeable 2/3/4 Channel Capability
Balanced Isolator Input Circuit
Oversized Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs (4-Channel)
RCA Outputs (Pass-Through)
Hi-Volt Input Level Control (400mV-6.5V)
Variable Crossover (Separate A/B Channels): 40-120Hz, -12dB/oct. (LPF/HPF)
Specifications
Continuous Power (14.4V): 50Wx4 (4 ohm), 60Wx4 (2 ohm), 120Wx2 (4 ohm)
Max Power (14.4V): 100Wx4 (4 ohm), 240Wx2 (4 ohm)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
bridge it and you might be able to push some comps.
I bought one almost like this used from here for 50$ shipped but haven't hooked any speakers on it yet so can't tell.
basic stuff, nothing fancy
Rob.
Rob.
Toronto Canada
Xprime4
