Pioneer faceplate only partially working
  • Thread starter Jmr82
  • Replies 0
  • Views 4K
Jmr82
Hello I'm am in definite need of some advice for my cd player. I have a pioneer avh-4200nex the double din touch screen. Here's my problem. Last night I thought I had splashed something on the faceplate in a panic I grabbed a shirt and went to wipe down. Luckily there wasn't anything spilled but I did notice that the touchscreen was acting strangely like not responding or delayed response. I assumed when I wiped the screen off I might have messed up some settings by the time I got home everything seems pretty close to normal. Now this morning I get in hook up my ipod like I usually do and the volume starts climbing like it's being held in but the volume forward and reverse and mute and eject buttons are not touch screen they are hard buttons on the bottom lip of the cd player. I understand hook the battery to see if that would work it didn't. After a while I was able to kind of wiggle the display a little and I believe I have the touch screen fixed I think but not the problem with the volume and noneven of those other buttons work either by the way. I figured maybe I rubbed a little too hard last night and it may have loosened the connection between the faceplate and the unit so I figured out how to get it off and looked everything over and nothing looks damaged on either area. I put it back on still the same problem then I did the reset where you use a paperclip to mash in the small button on the right still same problems. Has this ever happened to anyone before and can it be fixed by myself or will I have to pray pioneer won't charge a fortune to fix the issue. Any suggestions or advice will be greatly appreciated and thank you in advance
Jmr82
Jmr82
Athens tn
Jmr82
