Pioneer DEHP780MP EQ adjustment help!!!
edbtzy
ok i jus installed my new DEHP780MP headunit into my car...i read through the manual in AUDIO ADJUSTMENTS to know what everything does on the headunit to make my system sound a lot better....i tried many things but i do not get it at all...i dnt understand half of the things that i can set...is there any chance somebody could help me if they have the same headunit and tell me the settings they have...or wat are good settings...example: i have an option for BMX, COMP, BBE...i dnt understand what that is...also my sub...the frequency can be set but i dont know what it does...also the 16 band EQ can be set...i tried messing with that as well...
right now all i have is the sub set to 0 and "Loudness" on ON....n thats it...n i kno i can make it sound a lot better then it is but im gettin really frustrated...some1 please help if u can !!!
You can start by turning the loudness off. Adjust the 16 band one by one until you find what sounds best on that particular range. BMX and COMP are compression features for mp3 type files.
As stated earlier start with turning the LOUDNESS OFF. Loudness is for getting good bass and highs response at low volumes. So never set the EQ with that on. Next you need to go through each band on the EQ one at a time. Start with it flat and take each band all the way up and then decrease it til it sounds natural. Do this with each band.
On a side note, if you know someone that has an RTA that would be a good starting point towards setting a good curve.
BBE is a sound processing technology developed for recording studios that aligns phase relationships so the music has greater presence. This means, in your car, BBE adjusts low, mid, and high frequencies so the sounds arrive at your ears at the same time. This ensures that the lows are tight and well defined and the highs are clear and finely detailed. Listen to your favorite band and hear the true difference between guitar and bass.
edbtzy
edbtzy
Wayne, NJ
suleman36
