Pioneer Avic X920BT Whine issue.
  • 4
silvercookie
WRX
7,703
Queens, NY
Have a older pioneer avic x920bt double din in my 05 wrx currently.
Currently have a issue with whining through the speakers. Both front and rear speakers are currently running off the headunit.
It makes the whining noise whether the car is just in accessory or if its running. Has one of the black filter boxes on the Constant, Accessory, and Ground wires.
no whining through the sub though. and it doesnt fluctuate with rpm when car is running.
Sounds like a ground loop. My Volvo did that after I added a second amp. Check your ground connections, make sure your audio wires are as far away from everything else as possible. I ran my stuff on opposite sides of the car. You can add a ground wire to the stereo too, the little skinny black wire that's on there wasn't good enough in my case.
Put the phone down and DRIVE!!
I would guess it's time to send it to pioneer to get fixed
If it's doing it without the car running it's probably internal
You could always try connecting a 4 channel amp. If the rca output is still good but the internal amp is bad you could run the speakers off a 4 channel which would be better anyway
Yea i actually have a planet audio 4 channel i bought and have just been lazy on installing. I'll try testing it through the amp and rca's and see what happens before i go through the whole process of running rca's again and wiring etc.
Wasn't sure if this was like soldering the pico fuse thing.
Speskers running off head unit.
And i wasn't driving?
Either ground wire or bad RCA's.
No amp currently. Hesdunit has dedicated 12v from the battery and grounded to chasis.
Sorry, my header could have been more specific. Anyway, I might be the only one, but I want to get rid of the large AV source window on the main...
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
Download the manual. Should be some information provided. https://manualsfile.com/product/j0s9nlrgv.html
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
248
silvercookie
WRX
silvercookie
Queens, NY
Boomin_tahoe
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
