*PICS* did I recieve the recone I orderred??
I said I wasnt looking to divulge that
ANyways Im just about the check impedance when my gf gets back with a new 9v battery
I measured the coil and pole diameters though
My motor has a pole diameter of 2.946" and my recone has an internal diameter of 3.000", a difference of .054"
Is that acceptable??
What does it matter?
I cleaned the assembly and placed the recone in... gapzilla on the surround..... with the spiders just sitting on the landing.
You can still use the recone, the cone is just a bit too deep... but the next question will be whether or not the coil will be properly centered with the topplate... this is a good example of why 'drop in' recones arn't always ideal...
IMO you should try to return the recone for a refund.. then send the sub out for a proper recone, or get a drop in from someone who knows what is needed for that particular sub.. (I don't).. either that or get a recone from AQ which may or maynot be what you are after either...
strange! that is a really deep cone must have been designed for a 7" spider or a single linear 8". even with the spacers i but that coil is underhung. i would also send it back give ur guy a chance to make it rite for you.
i would be more than willing to build you a proper recone for that sub. i would just need to know ur top plate thickness and ur basket riser height...
I built that recone. The coil height is fine. It was mocked using spare HDC3 spacers from other HDC3 18's I have built and the top plate height I was given to use. I needed a coil with a longer former then the one I wanted to use. The coil here is a D2 8 layer alum flat wound coil I have stocked. The coil is dark from the the process of being wound at PE.. I used a stronger cone I like that's deeper, I have used them many times and work great.
if there is ever a problem i wish people would contact who they bought it from before posting. he could have cleared it up for you.
at least it isnt a high excursion sub cause gluing the surrond down with that gap will pull and limit the up stroke...
Jesus.
All that to find out he coulda called the guy that made it that day and his problem woulda been solved?
Get that baby reconed and lets see it.
AQ recones are ezpz //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
CoilBurner
Banned
CoilBurner
Waco
DaGrapeApeMan
