I use a circular saw most of the time, I've never really had any problems with them being off.. I kno what you mean though, Ill have to watch out for that..cool build.
did you cut that with a laser? otherwise the sawblade takes out a 1/16th of an inch, and your pieces wont be perfect.
also, what speaker is that?
audiobahn doesn't make anything that beefy?
customish thing with audiobahn dustcap?
Yea, your right Im gonna try for around 45hz and see what happens, I lost some decibels having to play that sweep tuning at 58 last time..You probably won't be the loudest around tuning. I would tune around 45hz or so and you should peak around 50-55hz. If you tune around 50hz, you may peak higher than 55hz which will hurt your overall run.
I am going to use 2 of them in this build.. should be loud either way, might not be the best but Ill find that out the hard way I guess..he said its an immortal... just an older version without the magnet coverhttp://www.cardomain.com/item/ABNAWIS15P
how many of those puppies are u gonna use?
the antenna plugs into the tuner thats located under the dash towards the drivers side.sorry for the delay of updates.. had to fix a neighbors radio.. anyone deal with FM radio problems on a 91 GMC Sierra truck? No fm, and no antenna spot or cable behind it.. hmm..
Andrew
im sure it can be done.Now I wish somebody would figure out how to build a good box to go behind the third row seat...
