Picking new sub stage
my last box was 36 x 20 x 20 but i had to take the whole trunk off and it fitted one 15...id rather not go that route again //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
the actualy trunk height is much higher then that but i did max dem of where the box can just be built and put in im not trying to do it myself in the trunk
then you will never get the potential out of the trunk space. Do a single high powered 12 with one of the aq amplifiers. should be able to slide in just fine and get loud.
how would one 15 in a 5.2 cube box tuned to 37 hz sound...im doing desings on RE Audios caculator...and came up with that or should i do two 12s
you can also cut out the metal in the rear seat opening to get more space....
yeah ive done most of the cutting...but the side bars...i think i may go ahead and cut those if i can find something powerful enough
i asked about an AQ 18 and he said i would only need about 5-6 cubes tuned to 38-40hz so if i can make the box about 18-19 inchs tall should i just do that instead of the two twelves
so you guys would choose the two 12s with aero ports over an 18 with slot?
I personally would go either way.....the 18 would be cheaper, and be more cone area, but then you are generally going to have to do a crx box style.
where as the 12s will give you a little bit more options for boxes
tapout383
Just boughta Zone.
tapout383
Virginia
tapout383
