Panasonic tuning
Set it on flat //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Your comps SHOULD be designed to put out an even volume, and if your subs over-power your fronts, try to find the EQ with the lowest bass setting...
There is no flat setting on the Sq just different Hz adjustments for the low/bass such as 60Hz-80Hz-100Hz-200Hz. The theres the Sq mid 500Hz to 1kHz to 2 kHz to 3 kHz Then theres the Sq High/Treble at 10 kHz to 12 kHzto 15 kHz to 18kHz. Thats what I meant to ask. So which setting out of these do I put it on.
shakewell519
shakewell519
Augusta,Ga
shakewell519
