Pairing amp with woofer
Recently aquired a Hifonics HFi1500 mono amp looked up specs and at 4 ohms 500w 2 ohms 1000w and 1 ohm 1500w. I'm looking to get a 15 inch woofer to run off this. Thinking of getting a dual 2 ohm coil woofer wire it down to 1 ohm and make sure rms is below 1500w. Am I correct on this? Don't got a lot of money but suggestions are welcome
Just did some research read these amps are commonly paired with the Alpine type r 15. 750 watt rms. One question should I get the dual 4 or dual 2 ohm type r? Wired down to 1 or 2 ohm? Seeing amp is rated at 1500 at 1 ohm and 1000 at 2 ohms my guess is dual 4 ohm coil?
In the price range. Now with the hds315 handling 1200 rms that means I would want to get the dual 2 ohm coil and wire it down to 1 ohm? I guess what I am asking is whatever option I go with I want the max rms of the speaker below what my amp is pumping out but not dramatically.. anything with a max rms below 500 watts I would want wired at 4 ohms so my amp would be pushing 500 watts? Anything below max rms of 1000 watts but above 500 would be wired to 2 ohms and anything max rms below 1500 watts and above 1000 would be wired at 1 ohm? Am I correct on this?
---------- Post added at 06:55 PM ---------- Previous post was at 06:54 PM ----------
Would you say those woofers are better than alpine type r? Both around same price
Smittster217
Smittster217
Corning, NY
Smittster217
