Overheating Speakers
  • 6
donmecca357
Hey All..... I’m having a serious issue with my current set up in my motorcycle. I have a Polk Audio 2 channel amp that has a max output of 125 rms per channel.... I have had Polk audio MM series marine 6x9 (150 rms max) , Polk audio db692 (150 rms max) and currently kicker csc693. The Polk speakers (both sets) have overheated and died (caps popping, magnets getting hot). The current kickers have a hot magnet and smell like it’s burning. I am at my wits end with this and about to take to a stereo shop and have them rip it all out and start over. Is there anything I could have missed that be causing this to happen? I have the amp gain at around 60%..... Way before distortion threshold .... any guidance would be awesome, Thanks in advance.... oh btw this is a saddlebag install..... amp and speaker in the left and speaker only in the right
thats not true. my Fosgate clips really low, like 40%. but it still does around 630 watts, rated for 500
set your gain right...
heres the tones...
I understand that I’m not an expert and that’s why I’m here but there is zero chance that I’m sending a clipped signal.... Unless I have a faulty amp, no amp should clip at 60% gain.... I do appreciate the feedback
Any amp I've ever had would clip at 60% gain unless you are running like 1 volt input voltage.
What is your source going to the amp?
Buuullllshit. then how did you set your gain to begin with? 60% gain turned up is pretty high and that's a hair past 1/2. As already asked, what's your HU?
Id look at getting more power.A 4 ch. would be ideal or another 2 ch to help with the heat factor for one running hot all day @2ohms at 60% gain isnt good on the amp.Set your gains correctly.This amp getting any air to try keep cool at all or stuffed away in an air tight location with no air circulation?
Hi Bud. I will be honest with you on this. All these units from Aliexpress dont last. they are junk. I have had one in the older honda civic 8th...
22
4K
it comes tomorrow and i cant wait. Thanks for spotting that amp and recommending it!
19
4K
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
193
377
It may be that they act like this because they are underpowered and the push to play them louder is causing the amp to clip the signal, which will...
donmecca357
donmecca357
Martinsburg WV
audiobaun
    Apr 27, 2024
audiobaun
    Apr 27, 2024
