Output and SQ questions
ARK_SWAMP_RIDER
I am building a system for SQ. I currently have a fosgate amp pushing 400 watts to 2 JBL GTO 10's (500 watt rms) in a sealed enclosure. I am looking at new subs. I am going with a single sub setup, either a 10 or 12. I like the IDQ10v3, and it is just a little over my budget to get the 12. I like the output of my 2 10's. If I go ported with about the same watts, would the output be equivalent? If this was done, would SQ be lost by porting? I have read the thread about sealed vs. ported, but havent found my answer to this. Thanks for any help.
Worry about the front stage first and the subs aren't much more than a filler. They should play the smallest portion of the freq range and have the smallest impact on the overall sound of the system.
too bad i gotta spend a boat load of money on my sub stage. my fronts will totally over-power the subs. 2 12"s ported want cut it... sux!!!
either you have like more than 3 sets of comps or you dont know what your talkin about
oh i know what the hell i'm talking about buddy. try 2 id xs69's per door paired up with some id cd2 neo comp full body horns. i don't care what 12's you run ported, the sub stage want be able to keep up //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
well usually when people talk about SQ teh loudness of the subs really doesnt matter much. I bet my SPL12s on the right power would hang with any front stage //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nah... want cut it. i listened to dual id xs6.5's paired up with pro horns, and the owners 2 jl w13's ported couldn't keep up. those new id drivers are loud as hell.
matt at id doesn't even know if 3 idmax 12's sealed could keep up.
A single 10, especially the IDQ, I hear doesnt have a lot of output. For that reason I was wondering if I could somewhat make up for that by porting, but dont know how that effects SQ. I could work on front stage, but I am just getting into this, and I am satisfied with the front right now. The quality of bass is what I would like to change, which is the reason for the switch. Thanks.
if your looking for some output with sq save your doe and get you an idmax and port that fvcker!!!
Since I doubt that the OP has horns installed and it is possible to turn horns down anyway who gives a rip if the subs can't keep up with a set of horns. Horns are the anomoly, far from commonplace anyway.
For SQ focus on the front stage. Since you are happy for now with how it's set up fill in the bottom end. In all honesty if the front stage is doing its job pretty much any sub will be up to the task. It doesn't have to be some mythical SQ sub just properly enclose it and give it an amp. The amp doesn't even need to be all that powerful.
ARK_SWAMP_RIDER
ARK_SWAMP_RIDER
Arkansas
ARK_SWAMP_RIDER
