OSB box
assassyn
my friend wants a big box for his 15"s and i said if he gets the wood i will help, well he has 12 4x8 sheets of osb.... so we are going to build his trunk into a huge box. HOW THICK WILL THE BOX HAVE TO BE? he has enoghf osb to make the box 3 inches thick
OSB = Oriented Strand Board. Wafer board is the old name for it. Used in construction in place of plywood. I would be reluctant to use OSB for a sub box unless you make it at least 3-4 layers thick. Most panels of osb I have used have lots of voids in them, and the wafers are not really well bonded together. I would suggest spending 30$ on a sheet of MDF, it is a much better material for a sub enclosure. JMO
assassyn
assassyn
Michigan
req
