Orion hcca250 or Sundown Sae1000d?
Which should I run on a Kicker 15L7D2. Orion HCCA 250 or Sundown SAE-1000D?
  • Orion HCCA 250
    Votes: 6 21.4%
  • Sundown SAE-1000D
    Votes: 22 78.6%
  • Total voters
    28
Yea I'll keep it but like I say tho. I'm stubborn I still might get one and try just to prove to myself the difference. Thought about getting the 1200d just to get a little more power to the sub tho.
Well I would definitely do that they are very underrated really put out around 1400-1500....
Thanks, looking at a couple of different ones right now if these others fall through I will let you know.
I wish you luck if you are trying to score one off of eBay. I can't tell you how many NON-WORKING, yet advertised as working, old school amplifiers I have purchased off of eBay over the years:verymad:
Some were minor fixes, whereas this was the worst hack job EVER on a Punch 150:
Sadly, had the idiot had the proper size fuses in the fuse holder instead of soldering wire across them, the rest of the damage could have been prevented:furious:
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif WOW that's nasty but not trying on ebay yet. There is one on here and a local guy(well about two hrs. away) that is going to let me here it play before we pull it out his car. So far the local guy hopeful will workout picking it up for a good price and knowing it works is even better.
Why would you want to use an amp for a sub that is going to a lot less efficient?
The main reason I asked that question is to see if anyone has bench tested or compared the two amps. I know the hcca amps are very underated amps as well as the sundown amps but knowing the hcca amps are so underated I was thinking maybe they might be close to the same. Besides the 250 would match my 225r I have running my mids/highs.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Because believe it or not there are people that actually believe running over 1k watts to a sub is ridiculous.
If my car's dinky electrical system can handle running my three amps, then they aren't really "a lot less efficient" as you put it.
FYI, my car's elec is a 90A alt and a stock sized battery, no dimming lights.
Plus, not all of us run our system @ 1 ohm. I am running a Rockford Fosgate 25 to Life Punch 150 on my dd1010 in my Civic. I tuned it go give me 600 watts RMS @ 75% volume but the amp is capable of producing 980 watts RMS according to its birthsheet. To get that kind of power in Class D at 4 ohms would have been much more expensive than the $150 I paid for the Punch!
eg9
eg9
Winston-Salem, NC
eg9
