Sold Orion, Eclispe, Stinger, TC Sounds, Alpine
Hintzyboy
Sparks mean its working!
Few items for sale here. Prices are OBO. PM me if you want anymore pics.
-Orion XTR Pro 1000 $250 shipped
8.5/10 Cosmetic
10/10 Mechanical
250 x 1 at 4
500 x 1 at 2
1000 x 1 at 1
Great pre-buyout Orion amp. Bit underrated (They generally do around 1200
or 1300 at 1 ohm)
-Custom Made 12" Dual-2 Ohm TC-9 (Built by Team PSI) $250 shipped
All-black motor assembly, black 4-spoke basket, black cone, carbon fiber
dustcap. Never been installed
Dual-2 ohm Voice Coils
Around 1200w RMS
-Eclipse EA2212 BNIB $100 shipped
50 x 2 at 4
70 x 2 at 2
150 x 1 at 4 bridged
-Stinger SWCKH44 Wiring Kit $150 plus shipping
Includes:
-Esclusive 1.2 Farad Stinger Capacitor with 4-Digit LED Voltage Display
-Four-gang, HPM Digital AGU fused distribution block
-Water resistant 4 gauge ANL fuse block with voltage gauge
-Two 16ft twisted pair RCA's
-Two Deluxe multi-output battery terminals
-Dual power-ground distribution block
-Multi-output distribution block
-22ft 4-gauge translucent blue power wire
-6ft 4-gauge translucent silver ground wire
-12ft 8-gauge translucent blue power wire
-12ft 8-gauge translucent silver ground wire
-6ft 12-gauge translucent blue speaker wire
-50ft 16-gauge translucent blue speaker wire
-Two position ring terminal in molded translucent case
-Four 60-amp AGU fuses
-150-amp ANL fuse
-Two grounding terminals
-All necessary hardware
-22ft of remote turn-on wire
-Alpine 3672 Acitve Crossover $120 shippied
Does 2/3-way front, 2-way rear, and sub
Bump.
Change of plans. Unless I get the requested price on the Orion and the TC9, they're staying with me. I just got a sweet deal on some mids and will probably begin installing soon. Everything else still up for grabs.
Aaargh //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif The shipping on this would kill me. More in my PM to you.
Wow, bringing this thread back.
These are specs Dave posted from another woofer, but he said they should be about the same for my woofer (except impedence). As for enclosure size, he recommended ~2-2.5 ported at 30-35 Hz. Not sure on sealed recommendations, but they should be roughly similar to the Soundsplinter RL-p, which is about 1.35 cubes (1-2 cube sealed range. The 1.35 is their "optimal car" recommendation).
Revc = 1.4987 ohms
Fs = 27.8046 Hz
Qes = 0.3320
Qms = 5.5769
Qts = 0.3133
Le = 1.3924 mH (at 1 kHz)
Sd =48168.8790 mm^2( 74.6619 in^2)
Vas = 45.4528 L ( 1.6051 ft^3)
BL = 13.6893 N/A
Mms = 237.5983 g
Sensitivity= 86.4357 dB @1W/1m
Sensitivity= 93.7095 dB @2.83Vrms/1m
Hintzyboy
Hintzyboy
Baraboo, WI
Hintzyboy
