Orion 2500d @ .5 Ohm???
blazrgreg
150.1db
I haven't posted on here in awhile but heres my question im running my orion 2500d at .5 ohm and the problem im having is my subs cut off at higher volumes.Also when the subs shut off the red power light on the amp still stays lit,maybe the amp goes into some type of protection mode when the volts drop too low???I'm running two orion h2's dual 2ohm everything is wired in parallel so I think the wiring is right??
I'm running a 200 amp alt & red top battery and still the volts are dropping a lot this amp draws some current.
I'm open to any ideas or suggestions so let me know people...
check to see what your dropping to. also see what voltage your battery is sitting at @ idle, in Drive with the e brake on.
Ill do that and let you know in a little bit I need to go somewhere that theres no houses.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
ive heard mixed reactions about running that amp at .5......if its worked for you for the past year though keep at it lol....but yea def look into adding another battery...id look into the kinetik or even a powermaster
try to get these readings
1-voltage drop at full tilt (use lil jon or something with a steady bassline so the dmm can catch up and give you an accurate reading instead of jumping around)
2-voltage of battery @ idle/system off with car in drive (trying to replicate sitting at a stop light, and trying to make sure the alternator is providing the full ~14v in that situation)
blazrgreg
150.1db
blazrgreg
va beach
blazrgreg
