its not that simple man. not at all.You can't repair the channel?
thats not good what sub was it pushing thats odd since the hu was on but on 0:uhoh: could the amp be repaired
considering its a mono amp, i doubt its a CHANNEL.sounds like the channel. man that sucks!
IIRC, Pioneer's go up to volume 62. Eclipse uses non-clipping preouts at full volume, except the subout. If you crank it up to max, 16. Then it clips @ volume 74/80. To get it to not clip on full volume. crank it to volume 11/16.Did no one else notice that he had the volume cranked full-bore? (52 out of 52?!?)
I would have to assume that the signal was overdriven to clipping...I'm surprised the amp went rather than the subs but no head unit I've ever dealt with outputs a clean signal at full volume...
Just my $0.02.
