Options on BL?
srt4100
Im gettin a Fi BL 12 in my trunk and im wondering which options to get? All of them?
P Chamfer
Cooling
Flatwind
Daily or SPL
Extreme Lead
Universal
I plan on getting all of them. Is that good. Should I choose daily or SPL? thanks guys im ordering it tomorrow morning.
Im gettin a Fi BL 12 in my trunk and im wondering which options to get? All of them? P Chamfer
Cooling
Flatwind
Daily or SPL
Extreme Lead
Universal
done. i guess you can get flatwind if you want. suppose to make for a little peakier driver.
go ahead, try to get the p chamfer and the cooling on the website....
there is a reason i said get the cooling //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
extreme leads arent going to make them any stronger. just more resistant to heat. if you bottom out a woofer and those leads are taking a beating, they will break whether "extreme" or regular.
back when Fi still used regular style leads, Fi stated the extreme leads can cause tinsel slap. but meh, they use leads sandwiched between he spiders now. you're not gonna break those, i wouldnt think.
btw, before someone tells you to search go to http://www.soundsolutionsaudio.com and go to the Fi forum. every option is explained for every woofer there including why you dont want the extreme lead and why you dont want the spl gap on a daily woofer
BL Series:
Available options and what they do:
The BL line is pretty much a lower power alternative to a BTL or a higher power alternative to the Q series of woofers. This is more of a street jamming type woofer that “fills the gap” if you will between these two series of subs. Keep in mind this is what we recommend, this is NOT what you have to do.
P Chamfer: This is a chamfer on the end of the pole, it helps to bring the air down around inside of the motor and helps cool the coil better. It also helps relieve the pressure underneath the dustcap. We recommend at the bare minimum to get this option if you choose this series of woofers.
Cooling: Self explanatory, the cooling channels are machined into the inside of the sub to help cool the coil FAR better. But there are some things that you sacrifice. There is less metal inside of the motor so it is a little weaker. If you are looking for a fart/burp only scenario for SPL we suggest that you do NOT get this option. Stick with only the P chamfer. Now if you are looking for a daily sub to beat on and you have less then 2000 watts then this is the option for you. 2000+ watts you need to look into the BTL series.
Flatwind: The flatwire coil option simply helps the power handling of the sub. The coil has more surface area to dissipate heat and will take more power then the regular round wire coil that comes in the ‘stock’ version of the sub. This option will also make the sub tend to be more prone to ‘peaking’. If you are looking to do an SPL install we highly recommend that you use choose the flatwound coil option. In testing it is louder then the regular roundwire coil and takes the thermal abuse much better.
Daily or SPL: Simply put, if you plan on listening to any type of music you MUST choose the daily option. If it is strictly for a fart/burp scenario then choose the SPL option. The reason we have these options is the gap tolerances between the two are different. The gap in the SPL woofer is much tighter and FAR less forgiving in comparison to the Daily option. The Daily option simply gives the coil more wiggle room inside of the gap to deal with the non-linearity tendancys that you can get into when you are using a sub in a daily driving scenario. Typically SPL applications deal with 1 note and it does not change, therefore we can make the gap much tighter and get all of the motor strength that we can out of it.
Extreme Lead: ONLY choose this option if you plan to use the woofer for SPL ONLY applications. This option tends to yield really bad tinsel slap and rubs holes in the spiders (especially on the 10’s and 12’s) it is not intended on using in a daily driving scenario.
Universal: This option gives you the choice to later chance the impedence of your voice coils. You can change from dual 2’s to dual 1’s and vice versa by reconing them. If you do not choose this option your motor(s) will be optimized per the coil resistance that you have chosen. (Dual 2’s will forever be a dual 2 motor, Dual 1 will forever be a Dual 1 motor).
BL 12 – Ported box we recommend using 1.8-2.5 cubic feet @ 30-37Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume.
Thanks. Im getting the Cooling, Flatwind, and daily driver. 319 shipped. I figured my amp would power the bl better than the hdc3. Now where to go for the perfect box? any help on that?
Ok, just ordered the Fully loaded Bl 12. Its going in a ported box in my 06 mustang. At Fi it says 32 hz is optimal for pounding and daily driving. Box specs say from 1.8-2.5. I would like to know the perfect box for this sub. I know nothing about boxes so im lost. Another reason I got the Bl instead of the HDC3 is because when it gets loud I still want good sq. Im looking for more spl but sq is a must.
srt4100
srt4100
atx
srt4100
