Opti2000D ratings don't add up
ultimate157
Engineering Student
I was looking through my owners manual for the Opti 2000D amp I have, and I noticed something odd. Here are the specs:
1 x 700 @ 4 ohms
1 x 1100 @ 2 ohms
1 x 1600 @ 1.3 ohms
1 x 2000 @ ½ ohm (MAX)
Assuming (MAX) means peak wattage, then 2000 x .707 = 1414 RMS watts. This does not make sense, because it is rated at 1600w @ 1.3ohms.
1 x 700 @ 4 ohms
1 x 1100 @ 2 ohms
1 x 1600 @ 1.3 ohms
2000 is the maximum ammount of rms wattage you will receive out of the amp... which is delivered at 1/2 of an ohm.
seemed pretty intuitive to me.
So a 2000 watt amp has to be played below 1 ohm and @ 14v to get 2kw out of it?
and yet a sundown 1500d ( 1500 watt amp ) will do 2500 watts @ 12.8 @ 1 ohm?
sounds like a real quailty amp to me /sarcasm
no its not the max rms, there is no such thing as max rms, there is only rms and max power, its talking about max power a .5 ohm
I didn't say max power in terms of the max power rating. I said its the maximum amount of rms power the amp is capable of putting out, with a specified ohm load.
Its rated to do its 2kw @ .5
There's just a discrepancy in the manual.
I also tested this amp back to back w/ a saz1500d... If i had made a vid i would post the results, but i didn't so i won't.
if you repeated the test i guarantee you'd be surprised.....But i'm sure you wouldn't say it, judging by the huge *** sundown logo in your ava.
Did you use a clamp meter to measure power?
ultimate157
Engineering Student
ultimate157
Worcester, ma
delvryboy
