Opti2000D ratings don't add up
non clipped clean signal, it does by definition.
But my real point was that he used a calculation to find RMS voltage for a power calculation.
Voltage RMS = .707 * voltage peak
Power is a factor of voltage^2. .707^2 = .5
Would you mind showing me how that is not true?
Brian
Not that I give a rat's *** about this argument, but since when did THD factor in when doing max power testing on an amp for SPL purposes. It's not like there's a critical listening phase of the judging...
Originally posted by 97Cavy:
Now... also keep in mind that neither Chad or Sean makes any claims about THD at this point. It could very well be high.
Sundownz:
Who cares about thd this is an spl forum....
3237 watts at 10.75 volts? wow thats about what I got out of a pair of powerbass 3000ds at the same voltage.... and the powerbass 3000ds were .5 louder then a soundstream 6500 so pretty much you are saying a sundown 3000 d is stronger then a soundstream 6500 on 12 volts?
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this test give 1877rms at 13.8V@1ohm
Brian
If you're talking about sine wave math, sure - but in car audio the term peak is not universally defined - you don't know what you're taking .707 of.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14079
$370 for a brand new one, from an authorized retailer.
And like I said before, 1 ohm nominal and 1 ohm reactive are two COMPLETELY different things. So why don't you add that to your little equation.
Arguing? Who's the one claiming big numbers without telling the whole story??
I got 4000 watts out of my zx2500 at .25 ohm on 18 volts
Did you "give up" or just realize that this is a battle you can't win?
You come into this thread about an amp that you've had zero experience with, talk shit about it, use that bashing to plug a product you run/support without even giving the correct info, and you're trying to act like I'm the bad guy here? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
http://www.allaudioexpo.com/nav/details.asp?itemid=1424&catid=71
299 w/ free ground shipping.
this will be my next amp for 2 type r 12"s @1ohm
So a 2000 watt amp has to be played below 1 ohm and @ 14v to get 2kw out of it?
and yet a sundown 1500d ( 1500 watt amp ) will do 2500 watts @ 12.8 @ 1 ohm?
sounds like a real quailty amp to me /sarcasm
whoa what!!! i thought i was getting like 1600 @ 1 ohm with 14.x V tops!!
I agree. . . .
I would assume if someone is taking power meaasurements for an amplifier they would be doing it with a clean sine wave, not music.
(my point still was the original post took peak power and multiplied it by .707 to get RMS power which is wrong. . . )
Opti's are pretty sweet amps, especially zed era. I have a 200.2(350x1@4ohm) that measured just under 1100w@2ohm.
If the numbers sound off, ask your buddies Loyd or Sean, they tested it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ultimate157
Engineering Student
ultimate157
Worcester, ma
delvryboy
