Opinions on this amp?
stay_high
Hifonics HFi2000D (HFi 2000D) Class D Monoblock Car Amplifier/Amp
MB Quart ONX1.1500D - ONYX Class D Monoblock Car Amplifier/Amp
I need a amp that does around 1000 watt rms to power two 12 inch audioque sdc2.5s. Are these good amps that will do rated power? I wana the mb quart amp but im kinda wondering why its only 169.99. Also my subs are dual 4's wired parallel to 2 ohms so i need a mono correct? Also is it smart to buy amps off of craigslist? Do they go bad and lose power over time?
wait a sec. Dual 4's waired parellel to 2 ohm= 1 or 4 ohms??? Which one is it lol cuz if its 4 ohm ill need a non mono amp lol whatever there called. Opinions on the hifonics amp?
each woofer to 2 ohms then wire them together to make 1 ohm ,and the hifonics ehhh,but why would you get used if you can get new for the same price or less
The ones i linked arnt used but i would get it cheaper if i bough used
Im starting to think the subs are 2 ohm becuase im currently running them off a kenwood kac-7205 and the amps specs are "250 watts at 2 ohms 170 watts at 4ohms. It says nothing about 1 ohm so that means the amp woudnt work with 1 ohm subs correct? Therefore my subs must be 2 ohms.
well he'll be good with that amp its not going to be to tooo much load to hes electrical depending on what vehicle he has
not but im running a 92ah rear battery with a good starter and still dropping into the 12s. but i just ordered a redtop hopefully it helps
Those hifi amps are trash. The onyx over the hifi
Really? I always heard hifonics made great amps but i guess im wrong haha. Got any opinions on soundstream amps? Saw one earlier that put out 1100 watts rms at 2 ohms and it was 198.99 new.
stay_high
stay_high
Florida
Ethan420Cox
